selling some race parts, gears, clutch parts that i am no longer using. some stuff has barely been used (maybe 3 passes in grass drags)
gears are 13 wide, have 18 and 19 top gear, 39, 42, 43, and 44 bottom gear. some stock, some lightweight aftermarket. $15 each
primary springs are a stock yellow/green, d&d yellow, and d&d teal. $10 each
helix’s are a speedwerx 61/55x, and the other is an unknown angle. $10 each
d&d deflection adjuster for cat act secondary. $15
d&d 3* timing key for small crank zr(was used in a zr600) $5
stock cat act secondary cover $5
121x15 camoplast touring track. 5/8" lug, 240 studs 1/2" penetration past lug. 3k miles on it, but still in awesome shape. hooks hard in hardpack, and works great in grass. its as close as you can get to running a speed track while still running trail stock classes in grass drags. very good top end speed with this, was very fast on my 800. one stud snapped off and missing, but no tears, nothing bent. $900 in this track, asking $300 obo, will also trade for a another track in the 7/8"-1" lug range.
204 stainless signature series studs, 1.070, used 500 miles, comes with brand new nuts. will make a deal on these to include with above mentioned track, these would stick out 5/8" past the lug. sorry no pic. $120.
also have slugged rear skid shock and bent torsion springs as well as cables for front shocks for zr/zrt chassis for grass drags. will make a deal if wanting to combine multiple stuff. also have other springs, helix’s, gears, and weights but may want more for that stuff as im not as willing to sell other items. ask, if theres anything you dont see but need.
