alright, going through the garage and cleaning out parts. longshot posting on here but im posting everywhere, maybe word of mouth can sell this stuff. some grass drag parts for zr3 chassis, other stuff for the snow. not running a zr in the grass anymore so this stuff wont work on the fcats and the other stuff wont work for my 800. already sold alot to a friend but this is whats left.
prices are best offer, shipping prices depend on item for if its included or not.
thundershift adjustable weights, 37.7 base gram. these are the best weights for the zr500-600’s in my opinion. work much better then the 10-56 polaris weights and you can adjust them. will work on all cat bushed primaries. this set is like brand new. SOLD!
second set of thundershifts, these are bad, only to be used as spare parts for the washers and bolts for extra weight. (extra bolts and washers are in the bag) SOLD!
set of 10-56 polaris weights, heels ground. weigh in about 54.5 i believe. holes are a little ovaled on 2 but they can last a season at a time with new bushings. $20
d&d 3 degree timing key. small key. $10
bent torsion springs and slugged rear shock. stick a bearcat spring with adapter coller in the front skid shock, tighten down limiters to 3.5", move rear scissor forward to slot, and tie down the front shocks and youll be set up pretty damn well for grass. suspension is huge when racing grass drags. just the torsion springs and slugged shock forsale here though. $30
dial adjust fox adjusting knob with mount bracket, and remote resevoir for front skid shock. SOLD!
used belts, good for spares. 1 012, 1 021 $10 for both
rox billet 5.5" riser for fat bars. $40
stock zr/firecat handlebars, perfect shape good handwarmers. stock 4" riser as well. SOLD!
fox zero pro front shocks off an '06 f6. one has a bent shaft but overall very nice condition. easily fixable. $50
also tie down cables for front shocks for grass drags. $5
