Bought all this stuff to build a super kart last year and just do not have the time to complete it with all the other things going on here at the shop right now. Parts are priced to move out now.
2005 Predator front suspension arms, hubs, brake disks, and spindles. Comes as a package, will not separate. Delrin bushings in all joints, zerk grease fittings too.
Fast Ace nitrogen charged coilover dampers. Hard anodized body, adjustable R/C, 10- 5/8" center to center mounting 250lbs/in spring rate.
Billet steering rack. Heim ends 14" C-C, 7/8" rack diameter, 5/8" splined steering shaft, 1.55 turns lock to lock, fully sealed.
ZX6R rear wave rotors, used but GC, 8.625" diameter, .200" thick, 4 x 4.725" BP.
New MCP lazer cut, blanchard ground steel kart brake disks, gas slotted, 7.125" diameter, .185" thickness, 4 x 3" BP
Tokico four piston calipers, Zx6R, used, radial mount.
Sold the rack to Mike, rest of the bits are still available here. Will sell everything else for $150.
