brand new performance parts
All parts are absolutely brand new and have never been installed.
WISECO PISTON KIT 87.5mm overbore
SOLD
CUSTOM thickness made a little thicker than the standard off the shelf gasket to compensate for machining of heads and or block to maintain correct compression ratio and timing
PAID $277.00
if you machine your heads or deck the block and use a stock thickness gasket you wind up increasing the compression, not desireable for increasing boost
Cometic’s Custom Gasket Department utilizes only the most sophisticated computer design and manufacturing equipment from initial design and engineering through manufacturing and finishing. Their close relationship with GM, Ford, Chrysler and Toyota in product development has filtered through their entire line of PowerSports gaskets and this same technology is available to you.
Today’s light weight engines are producing more horsepower with higher cylinder pressures, clamp loads and extreme temperatures. Cometic’s Custom Gasket Department can accommodate virtually any engine configuration from naturally aspirated to the most exotic turbo and nitrous injected engines.
Their commitment is to provide innovative, quality gaskets while maximizing your engines power and performance.
Cometic MLS (Multi-Layer Steel) head gaskets are made of 3 layers of stainless steel. Cometic uses stainless steel for increased strength, ability to rebound, and resistance to corrosion. The outer layers are coated with Viton and beaded for perfect embossment.
Viton is a fluoroelastomer rubber-based material that can withstand 482°F and able to seal the most harsh environments such as high load conditions and different surface finishings. Ideal for aluminum heads on cast iron or aluminum blocks. Withstands shearing forces created by aluminum heads/cast iron blocks.
No re-torque is necessary. Promotes an even torque load across the sealing surface, allowing for measurable reduced bore distortion.
this multi layer metal steel head gasket for a Nissan 300ZX twin turbo Z32 absolutely brand new, it hasnt even been removed from the UPS shipping box!
best reasonable offer
ASKING 199.00 USD
<img src="
ARP ROD BOLTS AND NUTS
SOLD
ARP MAIN BOLTS WASHERS AND NUTS, HEAD STUDS WASHERS AND NUTS
Made by ARP automotive racing products
The strongest head bolts and Main studs available. Period.
Don’t settle for anything less than the best for your Z.
These are absolutely brand new never used or installed.
ASKING 295.00 CAD
<img src="
Or make reasonable offer
