For sale some Honda and Acura parts:
B18B1 parts: out of 1997 Acura Integra
B18B1 complete head with intake and exhaust manifold including cams, rockers, lifters, valves, valve cover and everything, believe 2 valves are bent due to engine threw a bearing. good candidate for building $120.00
stock pistons and rods, 2 of them, good condition $30.00
stock oil pan, not tapped $30.00
Fuel rail with injectors and fuel regulator $40.00
original wiring harness $75.00
OEM head bolts $10.00
D16 parts, will fit honda civic, delsol and acura
aftermarket headers steel 2 pieces $50.00
original fuel regulator and injectors $25.00
Performence Parts
HF Turbo manifold cast iron for a b18 setup $35.00
Saab T25 turbo, was gonna use in turbo snowmobile, excellent condition, no leaks $75.00
Mitsubishi T25 Turbo off a 1997 eclipse GST, good condition, no leaks $80.00
Mitsubishi original TD-05 14B turbo off 91 GSX, might need rebuilding, no leaks, no play, could use for parts $40.00
stock O2 housing for 14b Turbo, off a 1991 Mitsubishi eclipse GSX $25.00
aftermarket O2 housing for Mitsubishi turbo with 46mm wastegate flange, stainless steel, never used brand new $50.00
Brand new 46mm wastegate, never used, black $85.00
Brand new never used G11 ultrastart remote start, for automatic, don’t have automatic anymore $75.00
I have a lot of parts from all the projects, lemme know what you need and i will give a you good price if buying bulk
Please no low ballers
also the items are located in Niagara Falls, NY
