I have few turbo parts leftover from projects
2G T25 Turbo charger, shaft play, with oil pressure, no shaft play no acc’s, wastegate tonge was cut out for using aftermarket o2 housing $75.00
T25 turbo off a 16V Saab with intake side and downpipe with o2 housing, wastegated and ready to rock, no shaft play $85.00
14B turbo, good condition, but consider it for repair because it’s a little stiff, $50.00
o2 housing stock off 14B turbo, askin $25.00
Aftermarket O2 housing for mistusbishi style turbo with 46mm flange brand new not used, stainless steel , it’s a vband setup $50.00
46MM wastegate, never used, brand new, bolted on o2 housing, $60.00
Resistor box for honda, with the male and female plug and clean 4 inch cut after plug $15.00
Utlrastart G-11 Model remote starter, brand new, never used, stainless steel remotes 2 of them, with boost manager or whatever that feature called, for auto cars, will work with manual cars also $60.00
B18b stock exhaust manifold $20.00
B18B1 wiring harness, good shape off 97 integra OBD2 $60.00
b18 Oil pan, stock, good shape, virgin $25.00
B18b1 2 stock pistons and rods $5.00
stock B18b1 fuel rail and injectors $25.00 for all
No texting please ~~
please call 716-285-1341 ask for Lee
if no answer 757-304-2227
