Parts located in Brampton/Oakville/Stoney creek/Vaughan Ontario, Canada depending on day.
Prices are in CAD, if you are American simply convert to USD at 20% exchange rate.
Hello, I am parting my car out and have many parts for sale.
Please visit my other for sale threads to check out many universal parts along with 1JZ/2JZ specifics!
For 1JZ/2JZ Oem parts CLICK HERE
For aftermarket parts CLICK HERE
If you are interested in a part and someone else out-bids you I will notify you and give you the option to counter bid.
Mishimoto Radiator.
-S13 fitment.
-Great for KA24 LS, 1JZ, 2JZ, RB20-25-26 Or any engine with upper and lower necks on the same side.
$180
Koyo Radiator
-Very high quality.
-S13 fitment.
-Very shiny.
$350
$180 Bings Front TC Arms S13/S14/R32/Z32/A31 etc.
$180 Bings Rear TC S13/S14/R32/Z32/A31 etc.
$200 Bings RUCA S13/S14/R32/Z32/A31 etc.
$350 SPL Rear Toe S13 Titanium hardware (like new condition)
$180 SPL Front outer tie rod kit w/bump steer correction S13/S14/R32/Z32/A31 etc.
-All arms have been cleaned and anti seized ready for install!
For SALE: S13/R32 SIKKY FRONT SWAY BAR
Features:
-lightly used.
-32mm tubular sway bar
-Perfect fitment for S13 with engine swap (LSx, RB, 1JZ, 2JZ, VQ35DE, etc.)
-3 way adjustable for fine tuning
-Added clearance when at full lock.
-Tire rubbing on the bar is no longer an issue even with extreme angle spindles
-No longer need adapter brackets, spacer blocks to run front sway bar
-High quality design and construction that rivals any bar for the 240sx that is currently available
-Lightweight.
Price:$300CAD just to compare if you buy it from them by the time you get it here it will cost you $500CAD
JDM A31/R32GTS/S13 4.383:1 Welded/Plated Differential.
-This differential was originally from my A31, fits R32GTS, S13, etc.
-Auto diff cover for higher fluid capacity and more cooling fins.
-4.383:1 Gear ratio, makes your car accelerate a lot faster.
-Center section has been welded and plated for bombproof operation.
$350
S13 Catch Can
-3x -10 Bungs for valve cover connections.
$60
Sony XPLOD / Swiss Audio Sub and amp combo.
-Includes short power and ground leads for trunk mounted battery.
$100
Kenda Kaiser KR20 Tires
-235/40R18
-Brand new set of 4, also many used for cheap ask about what I have.
-Set $380
-Pairs $200
Rare Size Nankang NS-2
225/35R18, great to be low with 18" wheels!
barely used, just purchased the pair for $250
Price: $150
Mocal Oil Cooler
-Great size for 1JZ/2JZ
- -10AN fittings.
Price: $140
Setrab Oil Cooler
- -10AN fittings.
- Highest quality coolers available!
Price: $180
Visor mount triple gauge pod.
I fabricated this to hold three gauges from the roof. The unit has been made to center over the steering wheel on RHD cars. I’m sure it will fit most RHD Nissan cars.
Steel construction, and holds standard 52mm gauges.
$120
AEM DRYFLOW AIR FILTER. Brand new in box. (made by k&n to AEM’S spec)
3" X 5" (3" intake pipe) (5" length)
Purchased this too long ago to return it, now I do not have a use for it.
Paid $88.13.
$80
