The cold pipe is probably too long. I have an s13 set up on my s14 and had to extend it a few inches. You might just have to cut a few inches of pipe off and reconnect it with a silicone coupler. As well, the brackets that attach to the lower rad support may not reach. You can get it to work with a little bit of work. You wont know for sure unless you try a test fit.
