Brake upgrade question
I found a complete 4x114 jdm integra type r suspension setup, and yes it is 4 lug not 5, i am wondering if this will just bolt in to my 95 civic, now i understand that some modification will need to be made to have the rears set up for disc brakes but otherwise will it work?
what all parts are included in the “complete” setup?
If it is indeed complete, then everything will swap over. If the trailing arms or anything is damaged just swap the hubs on the rear and whole front knuckles. That’s what I did on my 98 Civic.
TypeR 4x114 Brake Conversion. - Wheels not included. Kit includes Front and Rear knuckles, trailing arms, calipers, rotors, pads, and ebrake cables.
Sounds like you’re good to go.
yep it’ll fit, that particular 96spec ITR setup does not have the newer 36mm spindles so just slap it all on.
Forgot to mention that but dyingwish is right. You don’t have to make a set of axles or get the jdm ones. Good to go.
sweet thanks guys i think im going to order it
just to make sure, i have a set of rota wheels, judging by the pictures online they are either the fighter or the circuit 8, they have 8 holes so would they probalby be 4x100 and 4x114?
correct, make sure they are dual pattern…some Rota’s look like they have 8 holes but 4 are just machined for weight reduction
