FS: Willwood 4 piston calipers with aluminum mounting bracket (Honda and other)
I need these sold because they do not fit under my 15" wheels. For any of you will 11inch brakes such as Integra people, these should be perfect for you. They come with an aluminum mounting bracket which will work with all Hondas. PM or post with any questions ill find the answer and get back to you ASAP.
Hey Mike, what are you asking for them? Used or new?
Do only 11 inch rotors fit and which ones if so? IIRC a common EF/EG swap is G60 11inch rotors so if these calipers fit, they would be in bigger demand.
4 Piston? Damn. :thumb
I need to figure out how thick the rotors are that they need. They are brand new, one is still in the packaging. I forgot to mention, I have the Hawk brake pads with them too, baller shit you can change out the pads in seconds.
I THINK they work with the 11" eg/ek swap, but again I need to check the thickness.
Pssst… asking price :tong
still looking it up. .85 to .83" thick rotors will work, so yes 11" integra rotors will.
$350 unless someone can find a reason why it should be less.
I will gladly take these off your hands if they will clear my 15s on my GS-R
They are supposed to clear 15"s but apparently it depends on the specific wheel.
I’ll throw in the SS lines with all required fittings for $80. If anyone wants just the whole kit Ill sell it to you for the price I bought it for and i’ll eat the shipping cost.
This kit uses the OEM style 11 inch slotted & dimpled rotors, with the 4 piston calipers. Kit contains all the necessary parts, including the aluminum 4 piston calipers, slotted & dimpled rotors, aluminum adapter brackets, performance brake pads, front braided steel brake lines, bolts, etc. Normally requires 15 inch or larger wheels, factory wheels will fit, sometimes a thin spacer is needed. Calipers now available in RED and polished. This kit fits Pro Race 1.2 14x7 +38 offset wheels!
$680
