Some parts for sale, tryin to clean out the garage a bit.
S14 stock toe/traction arms - $10 each
S14 LCA’s - $60
S14 front LCA’s - $60 each
S14 Tension rods (4) - $10 each
S14 rear sway bar - $20
Rear 5 lug Rotors - $20 for both
S13 stock sr pistons/conrods - $100
2 SR coil packs - $20 each
Megan A/F gauge - $25
Located in Whitby, pM is key
drive shaft for sale. if so. will it fit s13
yea its only half, and i dont think it will work, could be wrong though.
possibly interested in lsd … condition???
mint, came of jdm s14 subframe.
any chance you have front spindles for sale?
not ill have 4 lug front spindles for sale in a month or so.
diff is pending, lots of interest in other parts but all flopped
diff and rucas pending, rest is still here make me a offer, rear speaker tray gonezo, also got stock s13 sr pistons/connection rods and a couple sr coil packs.
will the diff fit an s13? if so and the other buyers floop ill come get it the same day let me know
you’ll have to swap the rear covers, the s14 only has 2 bolts and i think the s13 has 4?
diff/rucas sold. Also got a megan boost gauge - no pressure hose or washer, jsut the unit and 6 inches of wires out the back. Asking 30. Everything else is up for grabs. Best offer
tires gone, still got everything else
Bump also got 5 bkre7 iridium spark plugs with less then 1k on them. 40 bones and s14 axles $50 each
JPlatt
July 2, 2010, 5:11pm
17
is the boost gauge bar or psi?
MIKE-240sx:
still got the rear lca?
Yea man and the boost gauge is psi
Mircea
July 6, 2010, 1:46pm
20
im interested in the boost gauge, do you think you can post a pic of it?
