2001 F-Body T56 Transmission
Built in 2007 by Six Speeds Inc.
1-2 Slider Assembly
3-4 Slider Assembly
Billet Slider Keys (3-4 and 5-6)
3-4 Steel Fork
1-2 Bronze Fork Pads
3-4 Bronze Fork Pads
carbon syncro ring kit
new GM 2nd gear
new GM 3rd gear
new GM 5th gear
Viper Shaft
- labor & shipping
Viper 30 spline DS Yoke (1350 series) included
New Slave Cylinder with remountable remote bleeder
Clean and Painted
Mobil 1 ATF, changed yearly
there is minor bearing noise, but nothing to lose sleep over. Tranny still shifts tremendously, (when you have a clutch in front of it :mamoru:)
this build cost over $2000 alone, not including my oem tranny.
$1500 - i just want it gone, but pretty firm on the price
2001 F-body T56 Bellhousing
OEM Aluminum Bell
$125
Quick Time Performance SFI Bellhousing
Wound Steel, same application
Comes with block shield
low miles. So you can keep you legs when your clutch explodes
i had to grind a small spot as shown below to clearance for a pipe. in no way does it diminish integrity
$275 - cost $480 new plus shipping
Pro 5.0 T56 Shifter
$60 - i believe i paid like $150 for this
McLeod Adjustable Master Cylinder
New Improved Version - New this season
under 1000 miles
$225 - cost $330 new plus shipping
27 Spline (stock F-body T56) 1350 Series Yoke
$40
- $80 new
good day
