Pair of Infinity Reference 12" subwoofers in sealed box. ~~SOLD
Work great, were powered with Jensen KA2125 500 watt amp, and it POUNDED.
~ power range 50-300 watts RMS each
~ peak power 1,200 watts
~ frequency response 20-800 Hz
~ sensitivity 92 dB
Jensen KA2125 500 watt amp ~~SOLD
Works great, used to power the Infinity sub woofers. Loud and Clear, sounds better than you would expect.
Also, have a Jensen KA2500 Amp. Used to power a single 10 in slot ported box (at 1 point), and also powered (2) JL 12w0 subs. Used to push 140.4 dB at DB Drag events. ~~Asking $50
Brand New 7" Indash Screen. ~~Asking $60
As you can see in the pictures, it has never been installed. The wires have never even been stripped. Hooked up to power 2 days ago to check it out, and works great. Does not play CD’s or DVD’s. It is a screen only. Will need an external player of some kind.
