i was doing the harness up for the sr20 swap, and noticed that a wire was pulled out from the CAS connector. is there any way to pull the connector apart to put the wire back in it? it’s wayyy too short to splice back together.
Can you post a pic of the broken piece. I"ll look to see if I have a leftover from my track car cconversion to Bigstuff3.
Jeff
i can give u another cas plug, and then just re wire it without having to re pin the plug.
