Chevy S10 Parts
Picked up a 1999 Chevy S10 Extended cab Auto 2wd 2.2 I4 motor
If you have parts let me know. Looking for some exterior parts and some interior parts
Thanks
I have 2 Blazers and 1 S-10 for parts what do you need?
Jeff @ 716 570 3082.
Tailgate and maybe third door
Color of truck?
Only a single cab… Tailgate is trash…
Dang
How about the seats?
What colors the truck?
so you never got back to me on that 8.5" axle. was it 2wd or 4wd?
They are all 4wd I apologize I completely forgot about it.
Both are black, only good body panel I have you could use is a passenger door. Interior is tan leather. I have gray and black interior pieces but no other seats.
so the fenders and bed are junk?
is the dash tan? im looking for the vented plastic piece on top. have it?
Its a Long Box so bed is useless to you.
Yes I have the tan defroster vent cover! lol
I have 1 good right front fender but it has a small crease in it. It is black.
I also have a sandstone fender I don’t remember which side it is have to check.
How much for the plastic piece, few bucks?
If the other fender is driver I may be interested
I have a complete 98 Blazer I’m going to throw On CL this. May part out if the price is right. Don’t know what parts would be the same but its rust free and the interior is very nice. 4.3L swap maybe as well?
is it possibly an xtreme / zq8 package with a 2wd 8.5" rear diff? lol
4dr 4x4 runs and drives great. no rust
Can the blazer rear gate be converted to a tailgate for the s10?
Btw, what’s the difference between a 7.5" and 8.5" rear end
no idea here
no, tailgate is way different.
8.5" is stronger.
stronger for towing, nice. is it a normal swap between the two?
what about gear ratio? does it change that at all?
Bolt in swap if 2wd to 2wd. Some had drum some had disc so you may have to modify some for the disc. Being that your truck is a 4cyl auto it will have 4:10 gears. Most all 8.5 rears had 3:42 beihind 4.3 5 speed and 3:73 behind 4.3 auto. Still a 10 bolt but larger ring gear diameter, stronger case. They’re round with square nubs on bottom instead of oval with hooked nubs on bottom. Better axles too and usually had the junk g80 gov bomb factory locker.
You have no need for one in your truck, however if you find one let me know. Im looking for one to build and put in my s10. If you have any specific s10 questions just send me a pm.
