I need the rear mount bracket from a 99-00 civic SI. it bolts to the motor and then to the mount. also need the mounting block that bolts to the side of the engine about 6 inches above the crank. and last i need a honda 5 wire o2 sensor. 315 573 6525
i have some si stuff…confused on what you need as far as the mounting block above the crank…you mean the ac bracket/tourque mount?
he means the actual mounting bracket for the upper drivers side motor mount (held in by 3 14mm bolts)
how much do you want to spend on the 5 wire o2 sensor?
honda wants like 400 so if it is cheaper than that. and that is the piece I need.
