So i found a great deal on a kegerator but it did not include a co2 tank and new tanks are a bit expensive. Anyone have anything there looking to get rid of or no longer use? Thanks!
check CL?
Also, we picked up a paintball style tank for a backup, dont want to run out mid-keg…
yes searched CL for an hour. will a 20oz paint ball tank need any additional fittings to work? Im only going to be using 1/6 kegs for my home brews so would a 20oz tank be sufficient?
Shit just realized i posted in the wrong section could someone please move it? Thanks
you will need an extra fitting. we got ours at the home brewery place on sheridan by military.
20oz wont last long, I would guess a keg or two, if that.
FYI, flying bison has a great way of handling the deposit on kegs (if you’re buying, not brewing). $45 for a 1/6 and the just take an imprint of the card, they dont charge it.
I have 2 of them.not sure what size but think 10lbs(27’ tall). has a regulator on it as well.
$20 for tank and an extra $50 for the regulator and reg. wrench.
Seem fair?
Ill take the tank but dont need the regulator, has the tank been tested recently?
Do the tanks have to be tested? Use a N20 tank. Why can’t you use your own compressor and just use compressed air over CO2?
so your using like the pop kegs? look for the co2 cartrages for like bb guns, and buy the adapter for them.http://www.kegworks.com/product.php?productid=21295&source=nextopia this should work good right?
this is on CL right now http://buffalo.craigslist.org/for/1380431047.html
yeah i saw that looks cool, im going to go with a larger tank though so if i decide to get larger kegs ill have enough.
if u order online go to kegworks.com u can go to there warehouse and buy shit its on militaey
I have a 20lb w/ regulator.
pm me if you’re interested.
needs a hydro.
