I can even just supply you with 2’’ - 3’’ straight/bends and you can weld it all up yourself if you wish ?
How are you doing your Cold Pipe ? I did mine in 1 pc and it still fits throu the stock hole from the air box system etc… do you just need a piece from the Turbo Outlet to the hole ? or a full piece…
Well I can supply you with piping or I need the car to ensure perfect fitment etc… If I made it the exact same as mine “I have a Megan Core” I cannot confirm it will line up with your Cooler, you may need to modify it ?
If he doesnt mind having to modify it perhaps to fit then I can have it ready mid next week as I will be making others…
Price is $150ea “hot or cold pipe”
Each piece is ONE piece… so only grommets @ cooler, throttle and turbo! none inbetween.
And yes you can make them in 1pc as I have mine done this way… “oh keeps stock battery location as well” I do not have to jack up my car to install/remove them either and none of the piping as poped off once!
