Guys I am looking for the shifter cable for a manual 1989 dodge colt. I tried the wreackers and the dealer, no luck!!!. The cables are discontinued so if anybody knows or have a colt let me know.
try using a talon cable
or neon
We tried the talon cable it’s to long, so you think the neon cable will work?
check with an after market jobber they might have one, i work on alot of older crap and havent had a prob getting anything
the cables off of a Mitsubishi Mirage or Plymouth Colt will also work. they are the same cars.
There is no after market cables
The neon one should work or try using one off the older hyundai elantras or accent the older versions both used mitsu engines before they switched to the beta 1 & 2 engines.
