alrighty long story short picked up a crv with water damage got the car dry and running but has a CEL on along with a nasty misfire. when i try to read the codes it just says unable to link… leads me to belive that the ecu needs to be changed (it was full of debris and corrosion) so it is a 98 crv 5-speed manual, do i need to obtain a 5 speed ecu or can i use an auto? also does anyone have kicking around that i can plug in to see if it resolves the issue then ill order one.
what does the lighter fuse have to do with the circuit tho? there was power to the obdII plug because my reader powered up and attempted to load data then would say unable to retrieve
in a honda, it has a solid cel that you cant get codes out of, the ecu is almost certainly bad. The only times ive ran across this is if the ecu is really corroded internally, and they are just about impossible to clean. You need a 5sp ecu i believe, but it might run with an auto ecu (just for troubleshooting purposes, not permanently)
