The Daniels AF8 has virtually limitless application within the wire range of 12-26 AWG. Over 1,000 turret heads or positioners are available to adapt the tool frame to your specific military or proprietary contact/wire combination. The eight impression crimp, which is standard in the AF8, assures absolute maximum tensile strength with almost every closed barrel contact. The precision ratchet controls cycling on the tool in both directions of handle movement. This assures the same, accurate crimp every time. Its like having a QC inspector at every work station. Positioners and Dies sold separately.
Trompeter Center Pin (TP837) Positioner for M22520/1-01 Center contact crimp tool Emerson - 010-0044
This positioner holds the center pin of a plug at the correct crimp height. It is used in conjunction with the M22520/1-01 center contact crimp tool. Use this positioner for the following parts on any Trompeter or MilesTek twinaxial or triaxial cable:
Trompeter Connector Series
70C
PLR70C
PLR155AC
150AC Large Body (using TRC-75-1 cable only) MilesTek Connector Series
10-06031-xxx
10-06032-xxx
10-06576-xxx
AF8 sells for around $300 and trompeter sells for around $200 = $500 msrp
I’m asking $150 for everything.
