The following package deals are in stock and ready for pickup now:
549 - boost, egt, link unit
779 - boost, egt, oil pressure, link unit
749 - boost, etg, oil temp, link unit
Here’s the gauge style for those who aren’t familiar:
The Link unit gives you a user definable warning level for each gauge, peak memory for each gauge, and it can record and playback a recorded run via stepping motor drive actuation of each gauge.
D-Gauges (52mm) - these don’t require a control unit:
Defi D-Gauge Boost (black) - 109!
Defi D-Gauge EGT Gauge Kit - 52mm Black Face - 400-2000 Fahrenheit range - 162!
Defi D-Gauge Oil Pressure Gauge Kit- 52mm Black Face - 0 to 140 PSI range - 162!
Defi D-Gauge Oil or Water Temperature Gauge Kit- 52mm Black Face - 80 to 300 degrees Fahrenheit range - 132!
We also have the new AEM UEGO 6 in 1 Gauge Type Widebands with sensor in stock and on sale for 335!!
These are extremely low prices folks. Look around and see for yourself!
They match the stock STi and Evo dash illumination…plus they look sick in anything. Hopefully I’ll have money to put them in the rally car come spring.
Night time, match is very good. Gauges also have a dimming feature that can be controlled day vs. night dimming.
I used the Lancershop.com gauge pod, it does not come with the tweeter grille, so I took the OEM one off the stock A pillar and fitted it to the lancershop pod for an OEM look and to have a functional tweeter still.
