im about to place an order from jegs for some AN fittings
the water inlet/outlets are 1/2" NPT
and the Oil out is 1/2"NPT
and the oil in is 3/8" NPT?
is this correct?
turbo is a GT35R
is this correct?
turbo is a GT35R
actually now that i looked at it
its gotta be
oil dump is 1/2" NPT
water is 3/8
and oil is 1/8?
ok, damnit they are metric… only ATP turbo had the information in their catalog
i still need to know the oil feed size
off topic, can you measure up the turbo ? i need to know the exact size of a gt35
what measurments do u need?
well im helping a board member fit a gt35 in front of his driver side strut tower on top of the frame rail
i need overall length, and then if your looking at the inatke and exhaust scrolls so they are pointing like this:http://www.japanvehicles.com/newcars/subaru/WRXS203/S203/015-001.JPG i need the height and overall width
ill probably have to clock the housings to the exhaust-inlet and the compressor outlet are straight down thru the splash panel, so i just wanna know what i have to expect
