Driveshaftshop Products
Aluminum Driveshafts
his shaft is about 5lb less than the factory 2-piece and will give the car a faster throttle response due to the fact the hanger bearing is not moving up and down during acceleration. A less expensive alternative to our aluminum shaft, it has been suggested by a few of the drift cars that we sponsor the steel shaft breaks the tires loose quicker than the aluminum. This steel shaft will give you most of the benefits of the aluminum shaft, without the cost. Please Note: Whether or not the car was equipped with ABS from the factory will change the length of the driveshaft. Be sure to check vehicle before ordering
Complete Rear Axles
Description:This is our level 5 system for the S13 and S14 platform. This set of axles has a custom outer CV made from 300M with our special bolt-on CV borrowed from our 350Z Level 5 axles. This system features 36 spline center bars (stock is 27), has our billet 108MM inner CV with conversion plates and hardware to mount to the factory diff stubs. These axles are designed for 1000HP at the wheels and are a direct bolt-in.
http://i91.photobucket.com/albums/k298/4g63telantra/ddsnissan.jpg
SHOP ONLINE HERE
http://www.garage16.ca/searchresults.asp?cat=888
