up for sale is the following
1991 4g63t 6-bolt engine, fresh rebuild with ~1000 miles on it
ACL rod/main bearing
OEM 1g pistions/new rings
ARP head studs
new oil pump
new water pump
BC 272/272 cams
freshly lapped valves
bc titanium springs and retainers
new valve seals and all gaskets including cometic MLS head gasket
new spark plugs/wires
oil pan has -10AN drain fitting welded on for oil return
SS braided -4 AN turbo oil feed line
n/a throttle body with FIAV block off plate
comes with alternator
-$1200 OBO
Band new BEP cast exhaust manifold with tial 38mm wg flange off of the first runner $300
two stainless steel manifold to turbo gasket (mitsu flange)
used one $10
new$25
red powder coated valve cover in ok shape, few scratches $50
stock ported 2g exhaust manifold $100
used oem radiator $50
Bare 2g cylinder head casting $150
2g intake manifold $45
AEM tru-time cam gears(red) brand new only bolted on, never ran sold
AEM high volume fuel rail with all fittings and AN adapter kit brand new it has never had fuel through it sold
spare set of stock dsm 450cc fuel injectors-make and offer
2g front cv axles $30 each
two front half shafts (bolt to the back of the block to front diff) -$35 each
2g DSMlink ecu with cable- sold to psi2high
2g knock off front strut tower brace $25
transfer case $200
2g 7-bolt AWD flywheel $50
freshly broken in ACT 2900 clutch with a 4 puck unsprung ceramic disk and 6 bolt AWD flywheel $450
1997 Eclipse GSX shell ~160k miles
Monarch green pearl
factory 17inch wheels with new 215/45r17 Maxxis MAV1’s
full 3inch exhaust
grey leather interior, drivers seat has wear
walbro 255HP fuel pump
little rust, underside edge of hood and hatch, quarter size hole on the strut tower and inside of drivers door
sunroof that works and doesnt leak
carpet in decent shape
stock suspension
all brakes are in good shape
comes with driveshaft
clean title
$2500 obo
im sure there is a ton more i cant think of right now, pics will be up tomorrow evening if anyone wants them.
