I have tons of DSM parts both OEM and aftermarket. Text me if you need anything
(518)396-7924 Call/Text[/SIZE][/B]
EXHAUST/TURBO:
-2G AWD Full Tanabe Exhaust 3" with Test pipe (Has about 35k on it and has a hole where the hanger came off and will be rewelded if needed) Sound good too!
Asking $265 [COLOR=“DarkRed”][/COLOR]
-2g AWD 3" Down pipe (It is in poor condition and has been re-welded a bunch of times. Not sure of name)
Asking B/O Plus Shipping
DRIVETRAIN:
-6BOLT AWD Fidanza Flywheel Comes with Flywheel bolts too.(Has only 8500 miles on it nut sure if it needs a resurface plate, One of the clutch bolts snapped off and will need to be drilled and tapped)
Asking $75 b/0
The Bolt the Snapped off
Selling a Stock replacement Clutch that hasn’t even been broken in. Has about 100-130 miles on it. I bought a GST spyder that the kid had just gotten a clutch put in to sell the car. It is a VALEO/OEM PHC ORGANIC Clutch Kit. I can also put a Clutch Master Pressure plate with 3k and make that combo. I also have the OEM Flywheel. I Sold the Throw out bearing.
Asking $70 B/O for the clutch/pressure plate and bolts. Or i Have a clutch master pressure plate that has 4k on it and i can do $90 B/O for that set up.
[SIZE=“3”]Still has the writing on the Clutch disc[/SIZE]
-2G 95-99 7Bolt OEM Mitsubishi Clutch Disc with 3500 Miles on it.
Asking $50
-ACT 2100 Pressure plate in okcondition Asking $ 45
-Clutch Master Pressure plate (Stage 3 Kit) 4k on it Asking $55
-OEM 7Bolt FWD Flywheel(With FlyWheel Bolts) Asking $65 [/B]
AFTERMARKET::
-Jegs -6an Stright fitting used $12
- Turbo XS BOV Flange $10
STOCK::
[B]ENGINE:
- 1G Exhaust Cams/Cam Gear ( Lower Miles ) Asking $30
EXHAUST:
-2G/1G Exhaust to Turbo bolts and one nut and stud Asking $15
- 14B J pipes with out nipple (2) asking $15
INTAKE:
- 2G Throttle body Elbow Asking $30
95-99 2G Turbo Throttle Body with Low Miles on it. Does not come with Sensors. Asking $30.
1G 89-90 Intake manifold with Injector plugs/clips Etc… no TB $40 b/o
1G 91-94 Intake Manifold ( No MAP Sensors) Asking $45
(x2) 2G intake manifolds $35 Each
- 2G Stock upper intake box Asking b/o
- (x3) 2G Intercooler Duct Asking $25 Each
SENSORS/COIL:
-Have just about any Sensor you can think of, feel free to email or text me if you don’t see a sensor you need. I might just have one laying around
-2G Coil Pack ( Low Miles ) Asking $40
-2G Front 02 Sensor (GC) Asking $30
- 90-99 Map Sensor adapter plate (lower Miles) Asking $15
x2 -2G Cruise Control Unit Asking $45 each
FUEL:
(x2)- 2G Stock FPR Asking $20 Each
- 1G Stock FPR Asking $20
(x2) -2G Fuel Rail (GC) Asking $30 each
(X2)-2G Fuel Line to Filter and filter (Filter has about 25k on it) Asking $20
COOLING:
-2G OEM Upper/Lower Radiator Hoses Asking $15 Each or $30 for the pair
-2G 7Bolt Water Pipe in Great Condition (Painted Black HiTemp) Asking $30
-2G Radiator bottom bushings Asking $10
- 1G upper T-Stat Housing) Asking $15
-2G OEM Radiator Cap One is polished with only 25k on it Asking $10 and other non oem with around 30k Asking $8
- 2G A/C line Asking $30
-2G A/C Condenser Asking $55
MOUNTS/BRACKETS/PULLEYS:
- (x2)(x2) 2G Bracket that goes from the engine to the power steering bracket. Asking $15
STUDS/BOLTS:
1G (6BOLT) OEM Stock Head Bolts (48k on them) Asking $15
Suspension/Drivetrain:
-x2 -1995-99 FWD Starter Both are in great working condition. Asking $55
-2G Power Steering pump Asking $45
(x2)- 2G Stock Shifter Asking $20 Each
-2G stock Brake Lines (With ABS) $15b/o
EXTERIOR:
-2GB Plate lights in great condition Asking $15
- (x2) 2G 97-99 Driver Side Bumper Cover Asking $15 b/o Each
- Galant VR4 Corner light covers ( GC No Cracks ) Asking $15
INTERIOR::
-2G Passenger side window/lock switch Asking $20
- 1G Leather Shifter boot (GC) Asking $25
- Galant VR4 Leather head rest ( No Rips ) Asking $35
Random::
- Eclipse Alum. Plates (new) Asking $20
SUBS, AMPS, ETC…:
-2G Factory CD Changer W/Cover(Missing the cd holder) Asking $50
- Diamond Audio 4" Aluminum Speakers. Cost over $300 new Asking $85
I HAVE PICTURES OF ALL ITEMS E-MAIL ME FOR THEM
