Engine Specifications
Top End (Nissan R33 GTR RB26 Head)
Parts Replaced
· Inlet Valve Guides
· Exhaust Valve Guides
· Inlet Camshaft
· Exhaust Camshaft
· Inlet Cam Gear
· Exhaust Cam Gear
Work Done
· Full Service
· Replaced and Resized Valve Guides (Inlet and Exhaust)
· Modified Exhaust Valve Guides
· Match Ported
· Mild Porting on Inlet
· Mild Porting on Exhaust
· Head Skimmed
· External Oil return (direct to sump)
Parts Used
· Original Nissan RB26 Valve Guides (Inlet & Exhaust)
· HKS Step 1 272 Duration 9.7mm Lift Camshafts (Inlet & Exhaust)
· HKS Adjustable Cam Gears (Inlet & Exhaust)
Bottom End (Nissan R31 RB30ET Bottom End)
Parts Replaced
· Pistons, pins and rings
· Connecting Rods
· Head Bolts replaced with Head Studs
· Main Bearings
· Big End Bearings
· Water Pump
· Oil Pump
· Crank Collar
· Idler and Tensioner
· Timing Belt
· Rear Main Seal
· Gasket Kit
· Oil Restrictors
Work Done
· Bored (Dummy head)
· Honed
· Line Bored
· Assembled
· Linished Crankshaft
· Replaced Welsh Plugs
· Balanced Rotating Assembly (8500 rpm)
· O-Ringed
· Drill and Tapped ½” Head Studs
· Fitted Idler and Tensioner
· Fitted Crank Collar
· Modified block to accept 4WD sump
· Blocked off oil restrictor
· Fitted undersized oil restrictor
· Modified Oil pump for external pickup (4WD modification)
Part Used
· CP 86.5mm Forged Pistons, Rings and Pins (~9.0:1 Final Compression Ratio)
· Forged H-Beam Connecting Rods (ARP2000 Rod Bolts)
· ACL Hardened Race Series Bearings (Mains and Big Ends)
· ACL Race Series Gasket Kit
· Nissan RB26 Water Pump
· Nissan RB26 N1 Oil Pump
· Nissan RB26 Idler and Tensioner
· Nissan RB26 Rear Main Seal
· Brass Welsh Plugs
· JUN Oil Pump Drive Crank Collar
· ARP Head Studs
· Tomei Restrictor
· Custom Made 4WD Sump Adapter
· Gates Timing Belt
ASKING: $9,000.00 CAD FOB plus shipping.
Remember this engine is to be transplanted into a GTR for AWD applications. Engine excludes harness, oil pan/diff and turbo’s. This will be best suited for someone who already has a R32 GTR and would like to have some massive fun. Everything from your R32 GTR will make this engine work in your car and will leave you with your RB26 long block with cyl head to sell at your discretion. This engine is built to ake 600WHP depending on turbo setup. Factory turbos can be used with factory injectors if wanted.
