Fluval Edge 6 Gallon cube fish tank
Doing some spring cleaning in the basement and I came across this fish tank that I no longer use. It’s in great shape, other than a crack in the top cover from me installing a 2nd LED light since I had some small java fern in there.
Specs:
  • Stylish and contemporary 6-gallon small aquarium
  • Powerful and efficient 21-LED lighting system
  • 7600K high luminosity LEDs are suitable for aquatic plants
  • 3-Position On/Off switch: Bright Daytime, Deep Blue Nighttime and Off
  • Low voltage power supply increases safety
  • Sealed glass top provides spectacular high definition viewing and reduces evaporation for less aquarium tank maintenance
  • Equipped with powerful, easy-to-use EDGE filter with CycleGuard and 3 stage filtration to ensure clear water and a healthy environment
This sells for roughly $100 new right now, but I would take $75 including all the additional accessories that I have with it including: thermometer, gravel (Flourite- great for live plants!), extra LED light from 12 Gal model, algae magnet cleaner, foam cover for filter and heater.
