FREE old skol… Must take ALL:
IIRC everything works.
990-5183
990-5183
10 disc and amp ill take
edit just seen must take all… ill take it
I called & left a message
ahh it was a diff # that showed so i did not answer… sry… ill check and call back
if he doesnt ill pick up asap
903-6408
i should be depends on location and meeting up
hahah, 10 years ago this was a $1000 set up…
I’ll PAY you $30 for that amp shipped to 14035… not because i want it, just because it’s neato and i’m going to collect old amps like that…
it was likely a $700 amp when it came out… or more.
edit: for me to buy it must have both harnesses… i only see the power harness in your pic.
http://ampguts.realmofexcursion.com/Hifonics_Boltar_VII/outside3.jpg
sounds like a transformer… BOLTAR!
did anyone get it yet or no?
I REALLY want that amp
ill take that amp off u… i can pick up tommorow… were r u located? and the head unit actully if noone took it yet
ill take everything like the post says … lmk
i will be picking this all up from him
EDIT: time and place set… good deal
all audio stuff was pick it
:tup: i can now has a system
that amp was pretty bad ass back in the day. with the right set up it can still keep up with many of todays amps
Yeah it kinda does.lol
I just gave an HiFonics Aphrodite 6X50 RMS 4 Ohms 6 X 80 2 Ohms built in 3 way X-over, it was only 50 watts per channel but it powered all my high’s & mid’s and a HiFonics Atlas 1 X 400 RMS 4 Ohm 1 X 600 RMS 2 Ohm that powered my Lanzar Pro’s
