i was going to get the adjustable qa1’s but then realized that the knob to adjust them are inside the spring so itll be a bitch to change em… so what ratio do you think would be best for my dad’s chevelle ??
50/50 front shock
60/40 front ?
the rears are ac delco and semi stiff
mainly cruises and highway cruising but 3 track trips a year… and the hot rod nat’s this year
11’s are a hair away so with the new stickyier tires missing front swaybar and maybee some new front shocks itll get in there consistantly
Not that hard to adjust on the monte inside the coil, with a coil cut, :dunno:
the place they are at its very hard theres a dip in the lower A arm and the coils are pretty tight anyway…
i ordered some lakewood 70/30’s today along w/ radial mickeys, and 2 new rims, a step larger jets, and some other odds n ends. thanks to JJs and H&R block the chevelle is almost done
LOL you should just buy the car off your dad, you build the thing more then he does.
if it was mine it would be sold already for a 55 chevy
