Elemental designs E10k.14 (i think 14)
regaurdless, there are two of them, they sounded great when I had them hooked up in my sol, and they don’t take up as much room as most other subs so they can be put just about anywhere. even in a truck.
they are this style:
$35 each.
what kind of RMS are they doing?
and whats the voiccoil config.and size
ill prolly takew the pair
so you want 2 8’s and 2 10’s?
I’m having a real hard time finding the specs since its been discontinued. I bought these like 3 or 4 years ago and barely used them
Found it.
Looks like the picture in my first post is not the same one. Mine are not as deep. Here is a picture of them when i had them installed in the car:
[SIZE=1]Application Outline [/SIZE]
Spec [RIGHT]E10k Subwoofer [/RIGHT]
Sealed Enclosure [RIGHT] Yes [/RIGHT]
Vented Enclosure [RIGHT] Yes [/RIGHT]
Infinite Baffle [RIGHT] No [/RIGHT]
<b>[SIZE=1]Car Audio Box Size Suggestions Outline </b>[/SIZE]
Spec [RIGHT]<b>E10k Subwoofer</b>[/RIGHT]
Sealed ( small ) [RIGHT] 0.4ft³ [/RIGHT]
Sealed ( ideal ) [RIGHT] 0.5ft³ [/RIGHT]
Sealed ( large ) [RIGHT] 0.7ft³ [/RIGHT]
Vented ( ideal ) [RIGHT] 1.5ft³ Tuned to 30Hz[/RIGHT]
Vented ( DDLoud) [RIGHT] 1.5ft³ Tuned to 35Hz[/RIGHT]
<b>[SIZE=1]Car Audio Recommended Boxes / Blueprints</b>[/SIZE]
<b>[SIZE=1]Frequency Response Information</b>[/SIZE]
<b>[SIZE=1]Specifications </b>[/SIZE]
Qts: .48
Qes: .40
Qms: 4.2
Fs: 29.00Hz
Re: 3.6
Vas: 40L
Mms: N/Ag
Bl: 14.00T*m
SPL: 88dB
Sd: N/Acm²
Xmax: 12.0mm
Voice Coil: 50.0mm
Magnet Width: 4.900"
Cutout Diameter: 9.250"
Mounting Depth: N/A"
Weight: 0lb
Total Height: N/A"
Displacement: .07 ft³
Outside Diameter: N/A"
carbon flibber subs, for that weight reduction every honda needs.
srsly tho nice subs. cant wait to get a system going again.
GLWS!!
Mafdark
January 12, 2009, 4:34pm
10
Posted these dirt cheap to get rid of them. Someone wants them
