Get ready for AWD fun in the snow, this is a great running (with a lot of recent maintenance) Audi. This Audi has the 20V DOHC Inline 5 motor with the 7000 rpm redline. This is a rare car and was only made in 1990 and 1991. This is the same engine as the Audi Quattro. This car is originally from PA (clean) and has never seen a NY winter.
Has ~174,000 miles (odometer stopped at 170,5**, 300 miles after the inspection in October).
PM me.
Price: SOLD
Features:
- Heated Cloth interior (both work)
- heated mirrors, washer, key locks
- Automatic Climate Control
- Power moonroof
- locking rear diff.
- ABS
- Auto-check system
New items (less than 3,000 miles):
1)Timing belt
2)Distributor (Bosch)
3)Starter (Bosch)
4)water pump
5) timing belt idler
6) thermostat
7) crank seal
8) cam seal
9) spark plugs
10) Both radiators (ALL METAL)
11) oil drail plug
12) fuel filter
13) belts
14) air filter
15) New Pentsoin Blue coolant
16) New brake fluid (blue)
17) New power steering fluid
Upgrades/ preventive maintenance:
- I have installed injector adapters with new style bosch injectors ($325) from 034motorsports.com. The old Hitachi are know to fail and are ~$200 each.
- Dual piston front rotors
- larger parking brake springs (stock ones known to stick)
- Some kind of aftermarket 15" rims
Items replaced/installed by previous owner (most less than 1 year old):
- both rear wheel bearings
- rear struts
- tires (Continental Extreme Contact)
- rear door mouldings
- Stainless muffler
- lowering springs (I do not know the brand)
- Power steering pump
Items worth noting:
- A/C condenser was removed during radiator installation, A/C did not work, plus increased airflow to radiator. Will be included with the car.
- skid pan/ under engine piece is not installed, but will be included.
- small oil leak in the valve cover, will include new gasket
- part of moon roof liner is missing
- some oxidation of the clearcoat on the hood (see pics)
- cruise control linkage broken, comes with car
- exhaust gasket leak where the downpipe meets the cat., should be fixed soon.
