Edit: Wheels sold.
The system includes two 12inch Rockford Fosgate Punch Z subwoofers in a sealed enclosure and a Kenwood 800 watt amplifier.
Rockford Fosgate RFZ3412 Punch Z 12"
- silver polypropylene cone with black foam surround
- silver LXcursion steel basket
- four-layer voice coil
- frequency response 20-200 Hz
- recommended power range 50-150 watts RMS
- peak power handling 400 watts
- sensitivity 87 dB SPL
- top-mount depth 4-3/4"
- sealed box volume 0.375 to 1.75 cubic feet
- ported box volume 0.75 to 1.75 cubic feet KAC-72012-CH Power Amplifier
Maximum Output Power: 800 Watts
Bridged Power Output at 14.4V (1kHz, 0.8% THD): 460 Watts x 1
Power Output at 2 Ohms, at 14.4V (1kHz,0.8% THD): 230 Watts x 2
Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 150 Watts x 2
2-Ohm Stable
Power MOSFET Switching Power Supply
Power Input Terminals: Gold-Plated,Screw-Type
Aluminum Die-Cast heat sink
Ground Isolation Circuit
Quiet Turn-On
RCA Audio Inputs: Gold-Plated
Speaker Connectors: Gold-Plated, Screw-Type
Speaker Level Input Terminals: Screw-Type
Speaker Relay Protection
Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
Variable High-Pass Electronic Crossover: 50Hz - 200Hz, 12dB per Octave
Bass boost (off/+12 @ 90 Hz)
Line Output RCA terminals
System sounds great and is in awesome condition. I will post actual pictures if there is any interest. $300
