2 Regular H4 bulbs for S13 (need the H4 housings, much better than stock, only used approx. 2 months) - $10
OEM Front Hicas Springs- $10
2 H4 HID bulbs (ballasts not included) - Now $50 – “Tenon” (no-name) brand, used only about 2 weeks
– 6000K, white with purple-ish hint
– Minor modifications were done (filed plastic) to fit correctly in H4 housing
– Unshielded - shields should be added
– Good for: cheap HID bulbs if you want to get your own ballasts/shields, or to use as replacement bulbs if you can shield them or use in a good housing etc
– Includes most wiring except ballast connections
– Bulbs work perfectly, and have a halogen high-beam (hi/lo)
