I’ve decided to sell off some of my SR stuff as I have too much.
Here is a list of what I have available at the moment.
- Mint S14 SR20/T Engine Block.
I got this checked out my the machine shop and only needs a hone. 86mm stock bore.
Head straightness is within specs and has all main caps and girdles.
Block is perfect for a rebuild
Block is a virgin.
$200
2)Prepped S14 SR/T Engine Block.
This is the block that I ran last year in my Silvia.
Melted #2 piston. I was already running 86.5 Pistons, so it will need an overbore to 87mm.
As a bonus, this block has been polished; yes, the block is SHINY on the inside.
The machinist had a theory that if the block is smooth inside, that the oil will circulate better.
Will need to be decked and bored
$150
- S14 SR/T Crank
Looks good and ready to go
$150
4)S13 SR/T Bare Cylinder Head
If you need a head to build, this is it.
Head is straight, all cam caps there.
Missing some cam bolts but it is a good base to work off.
$100
- S13 SR/T Rebuilt STAGE 2 Cylinder Head
Everything on this head is new (rebuilt).
It was never run do to other events.
Head has been decked and comes complete with all hardware, valve cover, cam caps, etc.
Doesn’t include cams BUT Includes upgraded valve springs and retainers already installed.
This is a high revving, bolt on installation.
This is 100% and good to go.
$400
A lot of this stuff is in boxes and I currently don’t have any pics.
If interested, PM me
Thanks
