FS: 2004 gm 6.0 lq4 10k mile motor 1400$
as stated i have a 2004 complete motor here i bought for a projet but have to punt now has 10K miles paid just under 2k for it i need it gone it has only one problem it needs a valve guide and a valve the vehicle it came out of was stuffed and the valve cover was pushed up and bent the valve tip and broke the valve guide
these heads can be had anywhere on ebay for under 100 $
some one jump on this sweet deal you cant find these motors anywhere under 2g with 10K miles heads or not
you should email jnj about this
does he still surf here
Nope hes banned
hmm…how hard would this be to swap in a in my silverado with the vortec 4.3 do you have the harness
no just the motor edelbrock sells a carb intake and msd ign to run it
glws
strokingnova has a 2000 and somthing chevy so the carb wouldnt pass inspection
sorry i thought it was out of a truck or something…my bad
Basically your saying it needs new heads right??? I am interested and have cash, you can email me at dp506@yahoo.com or call me at 585-409-0813 (Dale), I plan on using it for an rx7 V8 swap, Thanks
you sure you want a heavy iron block in an RX7?
Yes I know the iron block is heavy, its been done quite a bit actually, but if you have an LS1 for the same price I would be interested.
why wouldnt you go for the stronger block ? i priced it out about 150 to fix it i was going to put patriot heads on it they are 1295 and flow well
nice price glws
