jimbo, if you can come and take the stuff off in a couple hours you can have everything for $200, is that cool?
bumper is off the car, has a nice busted 1/2 clear and the bottom plastic lip is in tact. all damage is just paint. the paint job i had was pretty shitty so it flaked off.
Steering column you can take off either car, coupe if you come soon enough.
all the other stuff was removed from my coupe, if you can grab it from the hatch its all yours.
pic of the bumper, all the damage is pictured, it’s pretty minor. probably wouldnt be hard to sand it off since the homo who painted it used cheap primer and didnt prep the surface properly before hand.
gas tank: wiring is in tact, the circle is of a slight seperation in the steel. i think that is the high pressure side too… i’ll take $100 for the tank and sending unit since it needs a minor repair.
no no, i mean so long as it only takes you a couple of hours, not that you had to come within a couple hours.
The green hatch will have the AC stuff you need, it is not yet at the shop, will be there in the evening late this week or in the afternooon on the weekend.
friday night might work, saturday or sunday might be better… it will give you more time and there is a chance that the car will be outside… so you will want to do it in the day time.
Sorry, I took it as I needed to be there ASAP. I work overnights on friday adn saturday but starting sunday at 3pm (when I wake up) I would be able to come then or any day afterwards since ill be on winter break. sometime during the week would be better but sunday would work too.
comon guys buy this stuff so it does’nt clutter our garage!! Since im a nice guy, i can help you guys out to the point if you need something and its on the car and im not busy that day or whatever…give me a heads up and ill see if i can’t make it a little bit easier for you guys and ill take it off so it’s ready for ya.
Just throwing that out there, and also depending on the part. Hope that helps bing
