I have a complete Aluminum 30mm 5 Bolt Brake Setup from a Skyline. It’s identical to the 30mm Z Brakes setup.
Comes complete with hubs, spindles, LCA’s with balljoint etc…
this is a straight swap for any 5 lug and you will not find a better deal than this. These calipers alone normally cost at least $300. This comes complete with pads, rotors, lines and of course the calipers.
Rotors have a thin layer of rust on em from sitting for a while and just need to be mounted and cleaned off. I would just give them a quick sand and mount them. There is still meat on the pads. A little on the low side but the pads are aftermarket race pads of some sort.
Assembly is still complete and comes with RS*R lowering springs and KYB Shocks for an R32.
You will not find a better deal than this.
$125.
Yeah, that’s right, complete 30mm aluminum Z brake setup for $125.
Please do not haggle with me on this price. It’s already stupid cheap.
These would cost you at LEAST $300 at any importer.
Pickup only from York Mills and DVP.
NO PM’S PLEASE!! CALL, TEXT OR EMAIL.
ronniefung@gmail.com
416.846.6754.
