FS: 5.0 & Mustang Parts
Most of this is off of my 1995 GT unless otherwise noted: All prices are OBO!
Stock e7 iron heads, 95k on them, nothing wrong with them - $50
Upper and lower intake maniforld for 94-95 5.0 mustangs - $65
(I have 2 sets of these)
EGR off 94-95 5.0 (doesn’t match bolt holes on older 5.0 intakes) - $20
(I have 2 of these)
Stock sn-95 throttle body 60mm - $25
(I have 2 of these)
Fox body stock throttle body 58mm - $15
Stock Fuel Rails for 5.0 -$35
Stock 19lb injectors, 2 sets, one set is like new -$55, the other set is well used -$15
Stock cam 1995 GT 95k on it - $35
Stock Subframe connectors off of a 1999 Cobra - $50
Stock Cold Air Intake off 1995 mustang gt - $15
Stock MAF for 19lbs injectors - $30
Brand new Trickflow 6.400 inch hardened pushrods - $65
Stock Smog pump off my 95 gt - $45
Stock front calipers off my 95 gt - $35
Pick up is preferred, I will add shipping to the prices above.
Pics upon request
very good seller! glws buddie
bump
where in west seneca are you located… ill take the fuel rail if you still have it
I live on reserve road, yes i still have the fuel rail
any chance the fron control arms & spindles are available?
negative, only the front calipers
BUMP
Also have a
New set of Ford Racing Hydrolic Lifters for a 302/351
Bump
