Hello all,
I need my room back! Parting out your car is not a good thing to do when you live in an apartment. I am selling the rest of my crap so hopefully I can sleep in my bed again sometime in the next 2 weeks. I will be updating this with more stuff as I uncover it in my room.
Seats:
Driver and passenger leather S13 seats, tan - $25 each, $40 for both
-Passenger side looks wicked sexy, driver’s side has tear on bolster
Flywheel
Newly resurfaced flywheel, never used since machining was done, still in the box. Unless you have hookups with a machine shop, there is no way you can get your flywheel resurfaced for cheaper than I am selling it.
$40 if you give me your old flywheel.
N60 Mafs x 4:
-These are physically the exact same as the Z32 MAF, I just believe that these can support less power. These MAF are good for up to 350 hp. Each one comes with pigtail, and all are in good condition. Asking price is $50.
Stock S13 Brakes, ABS
4 rotors and 4 calipers fully loaded.
I put these on last april, brand new, so they are still in terrific shape. I do alot of engine braking and mostly highway driving, so the pads and rotors are barely used at all. I would prefer to sell it as an entire set.
$160 for everything
S14 Distributor
Selling the distributor + used cap and rotor. I took this out of a working engine when I swapped it into an S13.
$40
S13 Hicas power steering rack
No leaks, and it has a better steering ratio than the non hicas racks. Who wouldn’t want it???
$60
S13 fuel sending unit + pump
Unit was installed new on my car a year ago. No rust, no problems.
$120
J30 Front brakes
Set of front calipers from a 1994 J30. Quick and easy upgrade over the stock calipers. Bolt right up and use the same lines as the stock brakes. They come with pads, but you should probably buy new ones.
$40
S13 5 speed transmission
5 speed tranny with 225 XXX km on it. Did not grind when pulled from the car. Does not have shifter, but comes with the release fork and bearing.
$100
S13 wiring harness and ECU
Uncut and complete wiring harness and 5 speed manual ECU.
$80 for harness
$40 for ECU
Turbos
I have 2 turbos for sale. Not sure of the make or exact specs, but they are pretty big. I was told that they are T3 flanged and have 60 trim turbine wheels, but I am not sure. One of them has it’s internal wastegate welded shut, and the other is externally gated. I will upload pictures soon.
$100 each
