Black like new selling for 75 bucks OBO. Comes with all the wires, but no instructions.
Specs:
The new Auto Timer can automatically determine the necessary amount of after idling time. A Manual Mode allows the user to preset desired idling times from 0 sec.~10 minutes in 16 increments. By inputting O2 sensor voltage, the Timer can also display theoretical air fuel ratio. Since the Auto Timer uses the factory O2 sensor which is primarily designed for emissions, the readings may not be as accurate as racing air/fuel ratio monitors. The Timer can also display critical data such as O2 sensor voltage and Battery Voltage. To prevent potential theft while running, the handbrake safety feature shuts off the vehicle when the handbrake is released without the ignition key.
Stock pic: (but black)
