Audiobahn 2002T Amp
* Brand New Audiobahn A2002T 2 Channel Amp
* Class A/B MOSFET Power Amplifier
* 2x50 Watts RMS
* 1x400 Watts Max Power
* 2 Ohm Stable Stereo
* Non-Requlated Power Supply
* Full MOSFET Circuitry
* Double Sided Circuit Board
* Air Induction Fan Cooled
* RCA (Low Level) & Speaker (Hi Level) Inputs
* RCA Outputs
* Variable Hi Pass Crossover : 50Hz to 750Hz
* Variable Low Pass Crossover : 50Hz to 120Hz
* Variable Subsonic Filter : 20Hz to 50Hz
* Signal To Noise Ratio : > 100dB
* 18dB Bass Boost
* T.H.D. : 0.02%
* 1/2/3 Channel Operation (Mixed Mono)
* Soft Start Circuitry
* 25A x 1 Fuses
* Dimensions : 11-1/16"W x 1-7/8"H x 6-13/16"D
* White Cloth Handling Gloves
* Audiobahn Window Sticker
* Frequency Response : 10Hz - 40KHz (+/- 1dB)
* 3-way Protection Circuitry: Thermal, Short Circuit and Overload; Cooling Fan
* Cobalt Blue Illumination
* High gloss Chrome Plated Finish
* Nickel Plated Block Terminals
* 4 Ohm Stereo: 50W RMS x 2
* 2 Ohm Stereo: 100W RMS x 2
* 4 Ohm Mono: 200W RMS x 1
Audiobahn ABass10 Sub
-10" 350watt
Sub + box are going for ~100, Amp about 70.
Looking for 100 for the pair
