Bought this from K&S years ago for a project that went down in flames. iirc I had to trim 2 of the mounting ears to make it fit the center console but nothing that affects its functionality. Otherwise its pretty much in like new condition, VERY little useage- mostly test fitting and lining up shift linkage, moving the vehicle around the shop, and around the block/neighborhood a few times. Needs a new shift cable tho, dunno if the one that came with the kit was defective or just cheap. Probably why B&M sells “upgraded” cables :roll2:
$100
