fs: blown sr20det + tranny $700
I have my old motor laying around that I dont need anyone because it takes up a whole whack of space.
This is why its blown:
  • I ran out of oil. Im pretty sure its just the piston rings, when the motor ran out of oil, it caused friction and wore the rings, created blow by and then wouldnt hold the compression in the 3rd cylinder.
The motor still cranks up and runs, i actually drove it home on 3 cylinders when it went.
Anyway its a redtop:
-unknown amount of kms
-Will come with everything except sensors, pumps, power steering stuff, injectors and wire harness + ecu.
-tranny will need new 2nd and 4th synchro’s
-clutch still has a bit of life left
Im looking for $700
pics:
http://i54.photobucket.com/albums/g116/dvstr1/IMG_1510.jpg
http://i54.photobucket.com/albums/g116/dvstr1/IMG_1502.jpg
(does not come with turbo, but comes with oem exhaust manifold)
contact me by pm only please.
Engine is located in Mississauga.
bump still for sale
I said play nice.
fine.
how did the motor run out of oil?
I was running an ems, it wasnt tuned properly and was running really rich.
It was running 12 psi when i last drove it. The oil wasnt checked very often, my mistake, as we all know sr20det’s are one of the most oil dependant motors.
After I ran out of oil and did an oil change, went for a drive, then the 3rd cylinder went, it couldnt hold any compression after all the friction because of the lack of oil.
that makes a lot of sense.
but we shouldnt post anything here since we arent interested in buying, and protecting the buyer obviously doesnt matter :slight_smile:
yeah i know, maybe i should toss in a wire harness. Except maybe actually give it to the buyer.
Any further trolling posts in this thread will result in temp ban and thread lock.
nice
700 bux is alot of what your asking, the most you will get is 150 max
Good job guys (Red_240sx and rb_killer). See you in 7-days.
