Up for sale is a set (6) of SARD 700cc injectors (used) for rb26dett:
asking $500 +3% if paying via paypal
ALSO
BNIB AEM EMS for the RB26dett engine. Direct plug n play
I will also throw in a BNIB AEM 3.5 Bar map sensor and Internal Air temp sensor. With all this you will no longer require the MAF sensors. I had originally planned to use this myself but htings have come up and I need to sell.
Normal retail for this setup is over $2000.
Asking $1550 + 3% if you choose to pay with paypal.
Located in Brampton
AEM’s Plug & Play Engine Management System (EMS) are for racing vehicles and plug directly into a vehicle’s factory ECU harness and requires no additional wiring or hardware. Windowsâ„¢ compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. An integrated tuning wizard allows users to create a base map specifically for a car’s configuration, regardless of what type of injectors, sensors, coils or other changes have been made. The AEM EMS’s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
Installs in minutes using Plug & Play technology—no wiring necessary!
Start-up calibrations included
Live help window eases tuning process
Set-up Wizard creates a custom base map for your car
System is fully enabled—Never pay for upgrades!
Free software updates on aempower.com
Uses all the factory sensors
Runs on Windowsâ„¢ compatible software
Fuel table automapping
Programmable traction control
Onboard 512kb datalogger
Up to 10 cylinder sequential fuel injection
16 general-purpose outputs
7 definable switch inputs
Electronic boost control
Soft cut rev limiters
Two step launch control
Wet or dry nitrous control
Definable knock control
Full idle control
4 EGT inputs with fuel control
16/32 hybrid high speed processor
Roger L.
