fs: Brakes - Upgrade And Replacement Parts----------- -----------------pics----------
You mean New Jersey in US right?
Yeah, Canada post quotes by state and not zip code, so that should do for now.
I still have J30 brake calipers and rotors, these are easiest big brakes upgrade for 240sx and are almost same as Q45, use the same pads and rotors and are 1.5lb/caliper lighter.
Still for sale:
  • Stop Tech High Performance Slotted Rear Rotors - $150/pair
  • Infiniti J30/Q45 front rotors (280x28mm thick, some surface rust) - $60/pair
  • Infiniti J30/Q45 '93 Brake Master Cylinder (Tokico BM50 -1" bore) - $50
  • Infiniti Q45 '92 Brake Master Cylinder (Tokico BM57 - 17/16" bore) - $70
  • Nabco 15/16" bore with line coming out on the left side.This one is great for turbo and exhaust clearance - $50
  • s13 7/8" Brake Master Cylinder - $30
  • J30 front calipers with brackets and sliders - $60
  • J30 front calipers, brackets, hardware and sliders(all you need is pads) - $80
Also for sale:
300zx TT rims
–>http://www.son240sx.org/forums/showthread.php?t=43044
Aftermarket, JDM, USDM - upgrades and replacement parts
–>http://www.son240sx.org/forums/showthread.php?t=38573
Also for sale 180sx complete front brakes set in very good condition: calipers with pads, brackets and all hardware plus rotors in 4 or 5 bolts pattern. Pads and rotors have brand new thickness and you are getting everything you need to upgrade your brakes here.
180sx front brakes are bigger than stock 240sx brakes and will give you much more stopping power. This brakes work with your OEM Master Cylinder and Brake Lines.
$130 obo/trade
hey do u still have the Infiniti J30 front calipers with brackets?
if so might be intrested in them
Yes these are still here
Also for sale:
300zx TT rims
–> http://www.son240sx.org/forums/showthread.php?t=43044
S14 Front Seats and Parts
–> http://www.son240sx.org/forums/showthread.php?t=43905
–> http://www.son240sx.org/forums/showthread.php?t=38573
Still for sale:
  • 180sx complete front brakes with rotors in very good condition - $130
  • Fastbrakes Slotted/Drilled/Coated 11" 4-bolts front rotors 180sx - $190/pair
  • Stop Tech High Performance Slotted 5-bolts rear rotors - $150/pair
  • Nabco 15/16" bore Master Cylinder with line coming out on the left side.This one is great for turbo and exhaust clearance - $50
  • J30 front calipers with brackets, hardware and sliders - $80
Also for sale:
300zx TT rims
–> http://www.son240sx.org/forums/showthread.php?t=43908
hey im very interested in the rear stop tech 5 bolt rotors are they still for sale? if so will you take $120
I did lower the price twice already. These are really high quality rotors.
I can trade, let me know if you have anything interesting.
Still for sale:
Also for sale:
Are rotors on 180sx front brakes same as on J30 brakes?
J30 rotor is 6mm thicker than 180sx rotor , both have same diameter 280mm (11")
Also for sale:
S14 Parts
  • Fastbrakes Slotted/Drilled/Coated 11" 4-bolts front rotors 180sx - Pending Sale
  • J30/Q45 front rotors (280x28mm thick, some surface rust) - $60/pair
  • J30/Q45 '93 Brake Master Cylinder (Tokico BM50 -1" bore) - $50
  • Nabco 15/16" bore Master Cylinder with line coming out on the left side - great for turbo and exhaust clearance - $40
  • 240sx Brake Master Cylinder 7/8"- $30
WORK Meister S2R - Forged 2-piece, JDM Rims
–> http://www.son240sx.org/forums/showthread.php?t=44847
S14 Parts
–> http://www.son240sx.org/forums/showthread.php?t=38586
17" Hankook Ventus tires
–> http://www.son240sx.org/forums/showthread.php?t=44834
  • s13 7/8" Brake Master Cylinder - SOLD!
  • J30/Q45 front rotors (280x28mm)- SOLD!
[COLOR=“Red”]Also for sale:[/COLOR]
S14 Parts
