I might sell the set that is on my 180 right now. I’m looking for something bigger if I find it I’ll let you know in a week or two.
Other than that I have very good quality rear rotors but you’ll have to redrill them to 4bolts - it’s easy(Stop Tech High Performance Slotted 5-bolts rear rotors - $150/pair).
If you want 5-bolt and big brakes upgrade for rear then I have all complete (all multilink arms, uprights, 5bolt hubs, huge 292mm vented rotors and painted red calipers with 99% of OEM thicknes, drum parking brakes complete with parking cables, backing plate, all bolts etc.) from J30. This is easiest and cheapest swap/upgrade you can get
-$250
I’m holding this set until next paycheck for somebody, if he change his mind then you can have it. If you don’t have rims for 5 bolts - I have pair of multipiece Enkei’s 16"x8+32 with tires - $150 with J30 rear set.
I have practically in new condition front brakes setup from J30 with painted red calipers, like new pads and aftermarket slotted/drilled rotors (this set was on a car for literally couple of days/weeks) plus brand new (still in foil) AgencyPower stainless steel front brake lines.
If you can re drill these rotors to 4bolts then you have awesome brakes for cheap which will last you long time without need for rebuild. Any garage can also re drill them for you for a couple of bucks.
Other than that you can get from me Fastbrakes Slotted/Drilled/Coated 11" 4-bolts front rotors for 180sx, you’ll need caliper brackets for these as they are 11" - bigger than stock 240sx rotors.
I can get brackets if you want or you can buy my front set of 11" brakes (currently on my 180sx and still good) that I plan to replace with new aftermarket set.
For the rear I have Stop Tech High Performance Slotted 5-bolts rotors which you’ll also need to re drill to 4bolt pattern. These rotors are top quality and will last you much longer and wont warp as easily as a cheap Chinese replacements.
lmk.
Hey, I was considering downgrading from my Brembo GT kit.
What do you have for a full frotn brake setup, calipers, braided lines, brackets, rotors, etc.
I just don’t utilize all of the brakes, and if I were to find someone interested in the brakes, I could downgrade easily and still have what I need.
Not sure if I’ll find anyone interested at an MSRP of $3195.00 US
If you have something in excellent condition, pm me the details and pics, and I’ll keep it in mind if I happen to unload my kit.
Thanks.
Dude, I hope you’ll find out what’s wrong with your Brembo GT brakes. That’s some serious $,$$$ brakes kit, but if you want then YES - I still have practically new J30 front brakes with aftermarket sloted and drilled rotors. If you need Stainless Steel Lines then I have brand new ones to.
Let me know - you can have all of that for probably less than a price of one of your Brembo rotors. Cheers
There’s nothing wrong with the GT’s, they’re just bigger than I need right now.
I’m talking with some guys on Zilvia about some trades, but I just wanted to see what you had kicking around.
I may end up keeping them, who knows.
Thanks for he reply.
Bumpage!
