I have 2 of these and they are 75 bucks a piece. They are brand new in the box. Was going to put them in the firebird but plan on going with a smaller setup. Model # is KFC-W3012
General Features
• MAX POWER 1200W
• 12" Woofer with single 4-ohm voice coil
• Urethane Surround
• Dragon Spider Design
• 2-Layer Voice Coil Design
• Dual Magnet Drive
• 8AWG Wire Capable Push Terminals
• Frequency Response: 39-300 Hz
• Sensitivity: 86 dB
• Mounting depth: 6-3/16"
SPECIFICATIONS:
• Peak Input Power: 1200W
• Rated Input Power: 400W
• Impedance: 4 Ohms
• Sensitivity: 86dB
• Free-Air Resonance: 32Hz
• Frequency Response: 39Hz – 300Hz
Also Have A set of 6.5" Components made by AL Audio, 250 Watts Max, 1" Soft Dome Tweeters, Crossovers, Grills
* 6 1/2" High Quality Green Injection Cone
* 20 oz. Magnet / 40 oz. Magnet Structure
* 1" High Temperature Aluminum Voice Coil
* 1" Soft Dome Tweeter
* Flush, Surface and Angle Mount
* External 2-way 12dB Crossover
* 250 Watts Peak / 125 Watts RMS
* Frequency Response: 70Hz-20KHz
* 4 OHM Impedance
* Sensitivity: 92dB (1 Watt / 1 Meter)
* Includes Two 6 1/2" Midwoofers, Crossovers, Tweeters, Grills, Wires & Hardware
The model # is GSK600 wanna get 40 bucks for these.
All these are brand new in the box.
