FS: DOHC neon motor for parts or whatever, - $75
Here is the copy from my neons.org post:
Basically, it came with my NYG, and I don’t want it. It can not just be dropped in, I would only recommend using it for parts. It sat on a pallet with no oil pan. It has a new timing belt, new water pump, new tensioner and idler pulley (they now have some surface rust on them), and it is complete wtih head, valve cover, etc… The holes were plugged, and it sat with the oil pan surface covered up, but I would not trust it without going over it.
It has an exhaust manifold bolted on, and some brackets. This could be parted out for much more then I am asking, I just don’t want to tear it down and see whats up with it. This motor was running when it was pulled (so I was told). You could probably use almost everything, just I would not trust the crank and bearing surfaces without getting them checked out first!
Basically, heads sell for ~ 100 bucks or so, so someone can take this whole motor for $100 or best offer. The timing belt cover is good, not cracked, comes with crank pulley, etc… Come pick it up, its at my garage. I’ll take reasonable offers and trades too. Just one big thing I don’t need in my garage :slight_smile:
I have since lowered it to $75, so come and get it!
–mark
