Price: $450.00 or b/o
Condition: Used, Used in Iraq, few minor scratches from everyday wear n tear.
Fits on any Pickney Rail System
Operation
- Optics: Transmission holography - parallax free
- Magnification: 1x
- Eye Relief: Unlimited
- Length/Width/Height: 4.9"x1.8"x2.8" (124x49x71 mm)
- Weight: 12.3 oz (349 grams)
- Temperature: -40 to 150 F
- Waterproof: Submersible to 66 ft depth
- Sealing: Fogproof internal optics
- Color/Finish: Flat Dark Earth (non-reflective black on some small components) or Non reflective black with hard coat finish
- Adjustment (per click): 0.5 MOA (1/2" at 100 yds)
- Adjustment Range: +/- 40 MOA travel
- Mount: USSOCOM requirements dictated dual quick release throw levers designed specifically for the Picatinny (MIL-STD-1913) mounting rail:
- Certain commercial variants of the MIL-STD-1913 rail specification may not be compatible with the SU-231/PEQ (M553) mounting assembly.
- The SU-231/PEQ (M553) base consists of (2) ARMS® throw levers and is only adaptable to rails that properly accept the ARMS® design.
- Return to Zero: Repeatable to 1 MOA after re-mounting
Heads-Up-Display Window
Optical Surfaces: Anti-glare coating
Window Dimensions: 1.20" x 0.85" (30 x 23mm)
Front Window Material: 1/8" solid glass
Rear Window Material: Shatter resistant laminate (3/16" thick)
Field of View (100 yds): 30 yds (28m) at a 4" eye relief
Standard Reticle: 65MOA circle with quadrant ticks with 1 MOA aiming dot
Electrical -
Brightness Adjustment Range: 110,000:1 brightest to lowest
Night Vision Brightness Range: 1000:1 with NV switch engaged
Power Source: 2 x 123 lithium batteries
Battery Life: 1100 continuous hours at nominal setting 12
Brightness Settings: 30 settings with scrolling feature (10 settings for NV use)
Auto Battery Check Indicator: Flashing reticle upon start-up
Auto Shut-down: At 8 hrs- programmable to 4 hrs
